converting from efi to carburator
smacbay_gt
looking at converting my 95 mustang gt from the efi to carb, was wondering what all i need to do. i am trying to make a street strip car, any info or knowledge would be greatly appreciated
306 squirrel
I did it it not hard at all. All u need is a carb fuel adjuster sum fuel line.. a distributer intake and carb.. i upped my ignition up and put in a aftermarket while i was doin it..
Win
Kennesaw, Ga
To each his own. There are a lot of people i know and have talked to that say they wish they would have stayed EFI
smacbay_gt
the main reason is im wanting to supercharge it, and i have always built motors with carburators, im dumb when it comes to efi
LAFENATU
EFI is so easy and simple to work with you wouldn't believe it.
What is it that you have problems with? Ill gladly answer any questions you have.
95 svt cobra
Supercharging a carbd car isnt going to be cheap. What you will spend in parts you could get your EFI setup built and tuned.
smacbay_gt
well i am having a problem with it running rich, the car is mainly stock but i have put and msd coil, underdrive pulleys, and a cold air intake on it, the t/b and maf and injectors are still stock, and i had it timed, it runs great if you are just cruisin but when you rev it rapidly and also between shifts it lags out real bad, i was told it could be that i have an injector stickin but i am lost.
306 squirrel
If u wanna go carb i wouldnt blame ya.. I changed mine over and i love it i drive it every day and never have problems.. I put a demon 750 on it and adjusted it a lil and i drive it everyday with no problems like it a whole lot better than efi..
Rice_slayer
You want everyday reliability from a built carb engine? You do know EFI was invented for many reasons, and reliability was one. Sure, you can get more power from carbs but that is slowly changing as EFI cars are defiantly running pretty darn fast now. I would never go to a carb'd car, my brother's old 80s 4 banger stang was bad enough, they are a pain to keep running in cold weather. Also, just because you're car has issues doesn't mean EFI is bad, it just means maintenance must be done :p.
95 svt cobra
You can have reliability and performance with a carb. It takes more work though but it can be done. I went through this same phase not too long ago. Wanting to go EFI-Carb. I researched a lot, ask as many questions as i could and came to the conclusion that its not the best way to go. Period. Its not as simple as buying a carb, an intake and a fuel pump. There are a lot more things that will go into play. If you dont know anything about carbs, doing this swap can actually make your vehicle run worse or not run at all. EFI is a superior design unless you are a carb guru with a lot of time and money to play around with. This is my opinion and i got this opinion from people who know much more than me.
306 squirrel
It runs like a dream with my 750.. It a secondary vacuum so all 4 aint fillin up at once only when i nail it they fill up.. But yea EFI to Carb is expensive i have bout 5 grand in motor and transfer to carb with mine.. it would prolly be easier just to get new fuel injectors.. and it is a whole lot cheaper to supercharge a efi car..
Lebedin8654
I am looking into doing the same thing. And from reading the OP i dont think he really wants do debate is plans hes just looking for some tips or info on it. My opinion is it doesnt look that hard! You can run a 85 GT dizzy and ignition setup pretty cheap and simple. thats the ignition, than run a return style regulator on the fuel setup and there you go! Other than that you will need the intake and carb. You can also sell some of your efi stuff to help out with the funds on the conversion. Again this is just some of the stuff i have gathered and is just my opinion not facts!!! Also a carb setup can be very reliable, my step dad had a 70 Dart swinger it gets cranked 4 times a year and all it takes to get it going is a few pats on the gas and she fires right up no matter what the temp is out side.
Rice_slayer
an 85 mustang gt and a 94 mustang gt are COMPLETELY different. 94 actually has a good(well, at the time) computer in it :p.
Lebedin8654
You want to use a 85 GT distributor because its the only mustang to come with a carb and a hydraulic roller cam and a 85 GT does not have a computer.
