Cooling fan switch question - CCRM click
CVictor
What's up guys. I followed the write-up from this site on installing a manual switch for a sn95 car. BTW many thanks :thumbsup:
The question I have is this, when I ground it, all i get is a click from the CCRM. It's brand new so I know it's not a bad relay, but I can't think of what else it could be. It's grounded just fine, but just clicks. Any insight?
Here's the write-up I followed. Thanks in advance for the help!
By the way, the car no longer has air conditioning. I'm not sure if that'd affect the grounding of the hi-speed pin.
http://sn95forums.com/index.php/topic,10230.0.html
MikeF
I did not read the old post you have down but i did add a toggle switch for my coolant fan.just run ground to toggle switch and #17 to orther side of switch
C
CVictor
I just used the fog light switch. I could not figure out why grounding my hi-speed (pin 17) would not turn the hi speed fan on, but the wiring in the car has been modified by the last owner, it's got no accessories whatsoever so things get switched around. I ended up just hardwiring the fan.
