Cooling Problems
MyFast5.0
I have a '95 with a Vortech supercharger and no intercooler. Id like to get some kind of cooling system for my car because she gets a little hotter than she should be. I want to know what everbody recomends as far as how to cool it. I dont know if an intercooler would fit, space is pretty tight where it should go. What do you suggest? intercooler, aftercooler, alcohol injection... ect. Im in need and dont know what to do. Thanks
Mr. OAM
When you SC the engine you up the compression and this produces more heat. If your car's cooling system is not able to deal with the additional heat then you are producing heat beyond your present system's capacity to dissapate it.
You should look into the heavier duty aftermarket radiators with an extra row of cores or some other technology to increase your cooling capacity. Has it only begun to get hot since the SC'er went on? If so then this is the direction you should be looking in.
Steve
