cracked intake maniflod
Lightning Struck
every individual has their own way of doing things, you have yours I have mine.........so we will have to agree to disagree :) I would get the plates and let the rtv stay on the shelf.
19mustang95
DropTopPony said:
People have been doing the PI Intake swap for 3 years now and i have never ever seen or heard of anyone who used the PI head gasket and RTV have a leak. You do understand that the RTV gets dotted in 2 small areas none of which air go through so an air leak is impossible!!! 2 water jackets get slightly dapped in the corner and thats it. RTV does not brake down from water/coolant so failure is not an option. I'm sure there where some people who tried it with the NPI gasket and did hack jobs...but i'm no hack, i give accurate info that i personally know is good or i don't give it at all!
Thats all it takes!!!
See that little spot of black RTV
Which gaskets do i use the non-PI or the PI? and you only put the rtv on the front passenger side and the rear drivers side right?
Lightning Struck
good question since the ports are not the same ::) so the gaskets wont be the same either :p
good question since the prots are not the same and the gakets wont be the same ::)
DropTopPony
South Jersey
you use the PI gaskets...if you use the NPI gaskets then you have to use alot of RTV on most of the ports...this is where i think people get the idea that this is difficult and will eventually leak. But with the PI gasket it is minimal....heres pics
