Hey guys, having issues with starting my 95. I recently installed my battery to the trunk and now i getting crank no start, 12v is getting to coil but no spark, i have the fuel pump on constantly without the key even in the ignition and (ABS) and check engine light on without key in the ignition. My wiring goes like this:
Positive cable from battery to original cable up front
Negative cable from battery to frame where the tailight nuts are
Original negative cable bolted to frame up front.
Now i changed the CCRM. I checked all fuses and nuthing is blown. Havent burnt spliced or cut anything except the positive cable. I checked all my grounds for continuity and everything seems to be alright. When i pull fuses related to the fuel pump it still runs so my assumption on tht issue is tht i have a short some where but if thts the case wouldn't i be blowing fuses left and right? Also does the fuse box itself have a ground?
If you guys have any input i would greatly appreciate it.
