Crankshaft Pulley
red281gt
Anyone know where to get a crank pulley mine is wobbling so bad its making the belt slide off a rib on the pulley.
mdnitedrftr
Stock or aftermarket?
Stock, junkyard or classifieds.
Aftermarket, Im not sure of any suppliers that offer the crank pulley alone, usually its a kit. Maybe someone else has a better answer, lol.
is the pulley that's wobbling or the harmonic balancer. it's prob the HB and not the pulley. i got my stock replacement HB from o'reilleys but all should have em. or as some will suggest you should upgrade. my motor is stock HP so i went back to stock
R
red281gt
The pulley acts as the harmonic balancer.
also would anything else cause this to happen?
the pulleys being misaligned, or bent. have you recently changed an accessory or changed to UDP's.
im having the same problem... play in the pulley... :-( im just going to replace then entire set up... HB and different UDs.
R
red281gt
I just went with the steeda underdrive pulleys from AM. I also ordered up a fender grabber with the pony on it. oh yeah I ordered an Amsoil Eau air filter from Amsoil's site to see if there is any difference between the K&N filter i have now; also ordered their pre-filter for it to since the filter is in the fender.
