Custom Comp Cams???
98mstanggt
Louisiana
Ok a couple months ago i brought some used custom cams built for N/a from a guy for with 2500 miles he wanted $400 for them but i talked him down to $200 (he paid $700 for them) :laughing5: so i wasnt going to refuse that deal.......He told me with full bolt on's, Higher compression, Stage 2 PI heads, Full Exhaust, and a Tune he made 350rwhp..........My question is these some pretty good cams, are they pretty aggressive, also do you think they would go good with Trickflow New Heads considering they flow alot better cause if i could get at least 370rwhp with the New heads im def going to buy them.......(specs below) Thanks
Intake Exhaust
Duration @ .050 250 246
Lobe Lift .5450 .5450
Lobe Seperation 110.0
Open Close
Valve Timing @ .050 Int. 15 Btdc 55
Exh.53 Bbdc 13
Duration @ .006 285 281
Tappet Lift
98mstanggt
98mstanggt
Louisiana
sxynerd said:
He lied to you....
What are you referring to the Horsepower numbers if so i didnt really believe that but everything else is true i got the reciept, spec sheets, stickers, and everything else that came with the cams
NERD
Virginia
You'll need a fly cut for those and he lied about his Hp is what I was saying.
98mstanggt
98mstanggt
Louisiana
MustangChris said:
J.R. said:
If you put those cams into your engine, you'll ram a valve into a piston.
glad you asked... i would have hated to see a fellow stanger go down. :-(
Yeah i know thats why they still sitting beside my bed......But the New Trickflow heads have alot more PTV Clearance right???
MustangChris
Aurora, CO
i personally doubt it..... im not going to pretend to tell you what you have or let you think im a trick flow head master or anything, but if the heads are raised up, it would reduce the compression ratio. is this what you purchased? it would def. tell you if you changed your compression ratio.
if they just raised the CAMS on the heads, you would need new brakets to hold it down... i would imagine. and that would make taller cams useless in those heads... u know what i mean?
im afraid you will have to get a different piston set up, or have your pistons worked on to use cams that are too tall. or maybe just chop off the tops to each valve and spring :) lol. thats a good idea! (not)
Jrgunn5150
I saw where that guy said that, and it makes absolutely no sense whatsoever to me. PTV clearance comes from duration, and with 250 degrees at .050, you have a ton.
98mstanggt
98mstanggt
Louisiana
The specs are closer to the XE278AH cams and i know you need to flycut the pistons for the them.....Look like ima be fly cutting but dont plan on using the cams anytime soon if not at all depend on what i wanna do with the motor but Thanks for the Info
Zwolaver21
some info on the heads
Features & Improvements
?240 CFM @ 0.550? lift out of the box, Fast as cast intake ports
?185cc intake port, 93cc exhaust port
?38cc or 44cc patented Twisted Wedge? combustion chamber design, 38cc provides approx. 10:1 compression on OE PI short blocks, 44cc provides approx 10:1 compression on OE NON-PI short blocks.
?Intake Valve moved to opposite side of camshaft for improved mid-lift air flow, valve de-shrouding, and improved PTV clearance.
?Stainless Steel 1.840?/1.450? valves, lite-weight chrome-moly retainers and locks
?Drastic increase in PTV clearance, bolts onto OE Ford short blocks with no modifications to OE bore size or notching pistons with long duration camshafts up to 0.600 lift with OE type dish pistons. Flat top pistons may require additional clearance depending on camshaft
?Polished 205lb/inch rate valve springs for up to 0.600? lift camshafts, 90lbs seat pressure, 205lbs open pressure @ 1.020?
?Uses standard OE style 2V camshafts, followers, lash adjusters, chain tensioners
?Brand new castings Made in USA, Bullet proof 3/4? thick deck, Precision machined on modern CNC equipment.
?Aluminum Trick-alloy 4-bolt replaceable cam bearing journals
?Universal Romeo and Windsor valve cover bolt hole pattern, 8mm front cover bolt holes
?Trick-alloy powder metal valve guides, Ductile iron valve seats
?Viton? fluroelastomer valve stem seals with integral spring locator
?Full 3/4? reach spark plug bores, NO MORE INSERTS OR BLOW-OUTS
?Bolts onto Romeo and Windsor blocks without any oil hole modifications
?Provision for driver side back of head coolant mod
?Made in USA! Covered under U.S. Patent 5,873,341 and other patents pending
Jrgunn5150
People keep asking them how this is possible, and they never have an answer. Just because a "tech" say's it, doesn't make it true.
PTV is determined by duration of the cam, not by max lift.
realitygt
he lied about the power. there's a guy on corral with every bolt on imaginable with custom cams and stage 3 pi heads and he only made 330rwhp give or take a couple.
