dash lights Blowing fuse
smokeybear
Ok so the dash lights dont work on the 86 fox. I replaced the switch and the bulbs. the high beam indicator works and the clock dims any Ideas?
Dark_Pony94
Re: dash lights
I just had the same problem with my SN95. It was fuse 13 under the dash.
smokeybear
Re: dash lights
Thanks. :thumb: I had a dash Trifecta The switch the bulbs and the #13 and #4 fuse were all bad. it will work for awhile but the starts blowing fuses again :wall: :wall: :wall: :wall: :wall: :wall:
smokeybear
went to drive It his morning. BAM blow the # 13 fuse. If I put in a higher fuse It blows the # 4. So I don't get it. :wall:
smokeybear
It was the godamnd radio. the radio case was arching on the dash. they never used an install kit. just shoved it in. :wall: :wall: :wall:
