Dash Swap, now Question
lrall
So i swapped my tan dash for an 04 charcoal one. For anyone doing this, do yourself a favor and pull the inner fender out and unbolt the harness that comes through the fenderwell.. I can't believe nobody mentioned this or showed it in a write up.
Onto my question. I swapped in a double DIN radio but now i dont have any right side speakers. The odd thing is i had the most confidence in those wires. I guess I will double check them but is there an amp that controls one side or the other?
You have no front or rear subs and tweeters on the right side? nothing? the mach system has 3amps but they all run a left/right pair. Start at the top of the signal chain at the deck and trace your wires and check the connections. If you can try to do it with the radio on and give a gentle tug on all the wire connections to see if it comes back on to help isolate the problem spot
myStang95
Thanks for the advice. I'm 'bout to do a complete interior swap, and I have never had to remove the dash before.
L
lrall
Here is my advice, pull everything out but the dash. Then jack up the car and pull the inner fender out. Unbolt the big harness in there, PUSH it through, it has snap connectors. Then undo 2 gold bolts on each side, the vent bolts, the center ones and undo the obvious connectors. I could do it in about 45 minutes now. It was a GIANT pain to try and do it w/o the fuse block knowledge
