DDM Tuning HID Install Questions
98GTnSC
as the title states I'm wondering how hard/easy the DDM Tuning HID kit is to install. my kit should arrive tomorrow and wondering how long it should take to install and if it was easy or not it was to install. also where did you guys mount your ballasts? thanks for any help
Suspect
ATL
yea very ez. i took more time hiding everything then the actual install.
greenscobie86
The Big Apple
I hid my ballasts between the rad support/battery and the airbox on the passenger side. I used the big old ballasts from like 4 years ago. Cant see them.
The DDM thin ones should be cake.
On my old car I had the ballasts mounted to a bracket I made off the bumper beam. They hung in the bumper above the fogs, very slick install, but hard to get to if a ballast ever went bad...
98GTnSC
ok guys i just tried to get them installed and cudnt get the buld into the socket and all correctly. when id screw the bulb and all to the piece you twist to get off the original bulb off, once i got it all together what seemed correctly it would cock the bulb sideways @ an angle. everything else seemed as though we had it figured out though. ANY help would be great. or links to a DDM walkthrough
When i installed mine i had to grind off one whole side of the locking ring, cause it was hitting the base of the bulb and wouldn't let it seat properly...
greenscobie86
The Big Apple
Suspect said:
prolly like onyx said its not seating properly. i didnt grind anything, just put a lil muscle into it. youll know its set when it snaps into place.
Yup. I didn't grind anything either. It's a little tough getting them in there but you should be able to do it without much trouble.
98GTnSC
ok. well ima head back outside and try it again while i got a lil over 2 hours til dark.
hmmm, i'm 99% sure mine wouldn't have worked without grinding it. I took the whole smaller side of the ring down to that line that goes around the whole thing. it went in like cake afterwords.
98GTnSC
WE HAVE HID POWER!!!! yes! looks nasty since i didnt have time 2 hide the wires really. just tucked them 4 clearance and away from the radiator and such. but theyre running! and i didnt have to grind anything or use any of my man muscle to get them in. just had to get everything lined up JUST right. and thanks for the pic SUSPECT! GOT ME GOING!! thats where i had run into the bulb cocking sideways problem. but i appreciate all u guys help ALOT!
