HELP SMOG PUMP DELETE
RAU03MACH
NEW MEXICO
so the red dots your going to use some bolts to plug the smog ports on the back of the heads
back of engine
Y
Yellow95
unfortunately i don’t have means of pulling an engine currently but i’ll try my best to do it inside the car
Y
Yellow95
honestly i don’t need more than necessary, i just need the car running for a few mins at least, i gotta say i appreciate all of the information from all of you guys :)
Terrorist 5.0
I am not sure what the belt length would be with the stock crank pulley, but with my smaller size crank pulley, the belt length I used with a stock accessory drive without the smog pump, was 2226mm in length, although it was a bit on the longer side if I remember correctly. With a stock crank pulley, it would be a little longer. If I were you, drive your car to a parts store, go inside and pick up a couple belts, and try them on in the parking lot, excluding the smog pump. Once you find the right size, buy it, go home and yank the smog pump out.
Rsf1013
