Difference between GT and Cobra motor
883cobra
Hartselle,Alabama
Are there any differences between the motor that was used in the '94 GT and the '94 Cobra?Its not going to be much longer before the motor in my '94 Cobra will either need to be replaced or rebuilt(not sure right now which way I am going to go with that). I am wondering if the specs of the block(pistons,cam,crank etc.) are the same.I am guessing the intake and heads are different.
Also what year of the 302 blocks will work with the oil pan,intake and heads I currently have.Any advice to help educate this newbie will be greatly appreciated.Thank you
the cam, heads, rockers, upper/lower intake, injectors, flywheel etc are different but as far as the bottom end of the motor I believe it's identical to a GT.
Addermk2
Rumor has it that the flywheel is about 10lbs... However I find that to be a stretch.
883cobra
883cobra
Hartselle,Alabama
Interesting information which has got me wondering maybe I should have phrased my question like this...."What makes the motor in my '94 Cobra different from that of a '94 Gt?"
