disc brake service questions
lrall
so my bro needs new rotors on his 99 cougar. Hes going to order the rotors and i think were just gonna do em ourselves. Im familiar with this process in a noob sort of way. Jack car up, jackstands, wheels off, then first question. Do you have to squeeze the caliper w/ a C-clamp, i have heard you do so when you take out the guide pins(allen or torx correct?) the caliper will come off. Also, i read something about fluid coming out the MC?? Then hang the caliper by wire, then to take off the rotor you have to break loose and take off the big nut in the middle? When reinstalling this it should be torqued down to spec? Then take off rotor, install new one and reverse order. I'm assuming itd make sense to do pads at this time also? The C-clamp and gettin rotor off are the only parts im shaky on. Thanks for the help guys!! :banana: :banana:
97blackgt
jack it up, take wheel off, take caliper off (2bolts), remove old brake pads, push piston back in caliper(using a c clamp or special tool that turns piston while cranking in) install new pads, and caliper, and your done
97blackgt
Loosen the wheel nuts.
Raise and support the vehicle.
Remove the wheel.
Detach the caliper and anchor plate assembly.
Secure the caliper and anchor plate assembly out of the way to prevent damage to the flexible brake hose.
Remove the brake disc.
Remove the retainers (if equipped).
Installation
To install, reverse the removal procedure.
hopes this helps :hammer:
Hybridbird
No need to remove the nut.Just remove the caliper bracket and then the rotors will probably need a tap or two with a hammer to break them loose.
Peter
yah its not hard at all once you get the caliper off
best to get a new dust cap/cotter pin and dont forget grease
Hybridbird
He doesn't need to take of the dust cap or the nut,he's got floating rotors with sealed hubs just like us.
uncltrvlnmatt
Pa.
If you are replaceing the rotors, replace the pads as well. Do it once, do it right, or do it again.
