Connie
Thank you 96I love it!
Appreciate it PinkyT. I'm happy I at least was able to load the pictures correctly.His and hers????
Oh yeah, His and Hers!! I know...I'm supposed to be the one driving the Mach1. That's what most peoples reaction is when I tell them the GT is mine.Appreciate it PinkyT. I'm happy I at least was able to load the pictures correctly.
Thanks ttocs. I'll be checking into the Amp sometime next week, when my back can handle the twisting and turning under the dash.did you ever look for the mach amp in the dash? Because if its still there then it could very well cause this battery to go bad slowly, just slow enough to not be in the warranty period. You do not have to take the dash apart to look for it. If you look on the drivers side where the dash and the floors carpet meet you will see the obd2 harness that everyone tries to check. If you look back behind it towards the radio on the floor you can see the end of the mach amp, and the harnesses that plug into it. It is a silver box with a bunch of holes in it, behind it is the abs or airbag module I that is a light blue so its easy to tell the two apart.
Hi there ttocs. I finally got under the dash today, and the Amp Harness is disconnected. That's one reason I liked buying my Mustang new back in '03. YOU KNOW what is done to it over the years. And when I had my Custom CD System installed, I had pros do it,(at the wife's prodding)at a shop that's been around over 25 years. Instead of doing it all myself. I had to admit, it was an involving installation. And I most likely would've bit off more than I could chew.did you ever look for the mach amp in the dash? Because if its still there then it could very well cause this battery to go bad slowly, just slow enough to not be in the warranty period. You do not have to take the dash apart to look for it. If you look on the drivers side where the dash and the floors carpet meet you will see the obd2 harness that everyone tries to check. If you look back behind it towards the radio on the floor you can see the end of the mach amp, and the harnesses that plug into it. It is a silver box with a bunch of holes in it, behind it is the abs or airbag module I that is a light blue so its easy to tell the two apart.
