DIY: Spoiler/Wing Paint from Aerosol Can *PICS*
AutoBadges
Preferred Vendor
Los Angeles
Hey everyone,
Here I am back again with another project that I have put together. Some of you may recall a few years ago I attempted to do the
rear cobra shaved bumper, later I went to do the 01 Cobra front.....and finally I did the cobra side scoops. With each turn I
learned more and more and I think, became better and better at it. It's so difficult because PATIENCE in the key....prep time is the
most important, but the results make it all worth it. Ultimately this took me about 6 hrs from start to finish...give or take. So I
wanted to do a little writeup to maybe help any of those interested. Sure, I am not a paint master, so I don't expect paint shop
results either, but I think overall it came out great. NOTE: The final results are of the final clear coat, I have to let it sit for
24 hrs or so and then hit it with #84 rubbing compound and my meguiars buffer to get rid of the 'orange peel' but based on how my
spoiler/wing looked...this is 100000's better and I am very happy...even before buffing.
Items I used:
340 Grit
400 Grit
600 Grit
1500 Grit
2000 Grit (you can buy a pack for like $15 of all of these)
Water (free lol)
Microfiber Towels (inexpensive)
Painters Tape
Paper/Lining/Cover up for car (*I used dog pee pads cuz I had tons..hahaha)
Sanding block (very needed to sand over and over...hands don't do as well over large areas)
1 can of clear (aerosol)
1 can of L2 paint (aerosol)
1 can of primer
*Cans purchased from http://www.automotivetouchup.com/?utm_expid=46962982-10.mvu0xbPTQIKu4MxXEcvpMQ.0
I even purchased the sprayer that you attach to the can.....seriously makes it easier because you don't use your index finger over
and over. But when it came to gettting into the nitty gritty areas I pulled it off and used my finger to make sure I got in there
good.
So here is the car:
Here it is after I hit it with the 340 and 400 grit sand paper and the sanding block. It was so tough getting out that clear
coat....surprised me how hard I can to sand down....THUS why the sanding block was super helpful. I started by hand and the paper
got really hot with the motion and I had to keep pausing. Block came into play and BAM! Much easier.
Finally I taped off the entire car for overspray especially. I didn't go buy crap...I have a dog....I had doggy pads...I used them,
end of story..LOL Hey, it was there, and worked perfectly.....LOL.
Here is it with the primer now on it. Make sure that you clean it off really well after sanding it of course.
Then I hit it with 600 grit sandpaper in a wetsand. Some people freak out when they try this step and they lose some primer...that's
quite okay....the primer is rough, you just want to smooth it out with the water assisting to a super smooth finish before starting
the paint.
Dry it off and wipe it well because now you can start the coats of paint:
Please note that you should wait 10-15 minutes between each coat.
*ADDITIONALLY and EXTREMELY IMPORTANT: On your first coat of paint, do NOT try to cover every last inch. The goal here is to make
several thin coats that when combined will make for a beautiful finish. So you can see my first coat below. I just spread out the
paint, giving it some area for the 2nd coat to stick and grab. Again...just a simple very thin/light coat
Coat 1:
Then came the 2nd coat...a bit more on that one as the 1st coat allowed for the attachment
Coat 2:
Then you can see by the 3rd coat it's starting to come together. In this coat I make certain to cover all the areas up well
Coat 3:
Final coat it a nice top layer across it all for that nice finish. You don't have to worry so much about getting a super reflection
as the clear coat does that for you...but you still get some which is nice
Coat 4:
AutoBadges
AutoBadges
Preferred Vendor
Los Angeles
After about 1 hour of letting it sit, I hit it with 1500 wet sand and 2000 wet sand. I am on the cautious side so I was
suuuuuuuuuper soft when I did it and made sure to add LOTS of water...otherwise you just scratch it all up again, and I only had 1
can..so that wasn't happening. Sure you can get another can and put more layers and I may have wanted to do that...but I worked with
what I had. Then I dried and wiped it up well and started, my favorite part, the clear coat
The theory is the same....thin layers, moving left to right constantly
Through the progression of the layers you can see more and more of a reflection on the spoiler. On several of them you can see the
reflection of the flag on the pole and the 2nd story of the house being reflected and how much more it becomes clear with the coats
layering up with one another until the final coat is applied
Coat 1:
Coat 2:
Coat 3:
Coat 4 (final):
So here is the final results for today....6 hrs later. I am very pleased with how it looks compared to how it was!!! I will have to
let it sit, bake, cure, etc for a day or so and then hit it with the rubbing compound to get rid of as much orange peel as possible.
To be honest, even if I left it like this...it's already WAYYYYYYYYYYYYYYY better than how it was!!!!!!!
Now here it is the following day:
And to give you a better feel for the major difference.
(Yeah I know the car is filthy..but focus LOL)
Shifty Powers
Where the wild goose grows
Nice writeup and sweet job on the paint. I cannot use cans for shit.. So kudos to you sir
Did you do the underside? Would it have been easier to paint it had you taken it off?
Ninety8stang
Duh405
Looks good man! Car looks like it could use a good wash though. I would like to see a picture with the decklid clean. But great job man!
AutoBadges
AutoBadges
Preferred Vendor
Los Angeles
Thank you very much, I appreciate it. I did searches for how-to and they were just hard to find as well...so hopefully this can help other people looking to do it too. Overall it cost me like $30 because I had most of the other stuff from other projects. It is tricky using cans...you have to get used to them a bit lol
Didn't really do the underside...sun never hits the area...just did a light sand there and a few light coats. I didn't want to take it off because using it on the trunklid allowed for a good work bench for me to sand and paint. Additionally I didn't want to reapply 3M on the wing upon reinstall, etc if it needed it.
AutoBadges
AutoBadges
Preferred Vendor
Los Angeles
You and I both!! Car was disgusting because the weather made it just drizzle a bit to get dust to settle and look like crap on cars LOL I had just washed the car about 1 week ago too damn it LOL I will wash them today or tomorrow and post those new pictures up :) My wing makes the trunklid look crappy now as it's more faded/oxidized LOL But my rear bumper was freshly painted so they should compliment each other lol
Phatboy
Looks 100% better, but if you really want to bring out the shine, wet sand it again with 2000, then polish it with a polishing compound.
AutoBadges
AutoBadges
Preferred Vendor
Los Angeles
Yeah I thought about it...I have the buffer and #83 Meguirs. I hate wetsanding though cuz I feel like if I do it too hard it will mess up all my work lol
I would be afraid with the bottom not done that it will start to deteriorate from the bottom up. Looks better for sure.
AutoBadges
AutoBadges
Preferred Vendor
Los Angeles
I wouldn't. lol If it hasn't in 12 years....It won't in the next year that I will be having this car :)
boston2k4
Charleston SC
Looks good man! Cans are hard as heck to figure out and once you get it down your favorite brand swaps the spray heads to something "better"
and you gotta learn again.
AutoBadges
AutoBadges
Preferred Vendor
Los Angeles
LOL I feel ya. I had one and went to another and actually was happy because the paint actually matches better with the new one! LOL
AutoBadges
AutoBadges
Preferred Vendor
Los Angeles
Interesting...but I'm trying not to spend anymore money..thus the rattlecan job LOL
stillridin
