Does anyone know? (paul?) lol
G
GREG@SN95
Guest
Ok... heres my plan for tomorrow...
1. Remove the 8.8 out of the sn95 parts car I have
2. Remove the 7.5 out of my LX
3. pull the front brakes off the sn95 parts car
4. remove the front brakes on the LX
5. put front brakes and 8.8 into the fox
6. Restore the parts car back to a rolling chassis
Ok... pointers please...
I am not 100% positive as to whether or not the sn95 8.8 and the LX 7.5 is interchangeable... I was told that they are, but people talk stupid when they don't know what they are talking about. So I want to be 100% sure. I need the fox for daily transportation. If you know, that are are in fact interchangable with out a doubt in your mind, let me know.
Will I be able to do this in a day? Day and a half?
How do I compress the springs with out a compressor? Tips, pointers and advice are appreciated.
I was just looking under both cars. It doesn't seem like it would be a very difficult task... but I want to make sure before I dive into it and I have no car come Monday afternoon.
oh yeah... and heres why I need to do this.
1. The brakes on the LX combined with the bicycle tires are unsafe for the roads. Winter is coming and people around here drive like animals. You would not believe how many fatal accidents I have avoided. I am very thankful for the fact that I do not have ABS, cause I would have had to fight it several times... lol...
2. The rear is a time bomb. There is space in between the pin and the spider gears. I can actually twist the drive shaft a good 30 degrees back and forth. I don't want this thing to grenade on me and leave me stranded.
3. I want posi. One wheel peel + bicycle tires, again, not safe... Theres also something fucked up with that. I jacked the car up off the ground, I put her into gear, only one wheel turns. The other wheel wants to turn, it actually does turn, but very very very slowly and in very short bursts. So the limited slip is fucked as well...
Paul
Since the axle mounting points are all the same (as the chassis is the same) between the fox and the SN95, you should not run into any problems with swapping axles.
Are you going to be taking the entire SN95 spindle, hub, rotor, anchor, and caliper off and re-installing it on the fox? If so, I believe the brake lines are incompatible - but I would check http://mjbobbitt.home.comcast.net/~mjbobbitt/mustang/5lug.html to be sure.
What are you going to need a spring compressor for? The front springs?
Paul.
stang94X
everything is interchangable from the chasis, but the 8.8 from the sn95 is a little wider so the tires are going to stick out just a little bit, didnt know if you knew so i figured i say
G
GREG@SN95
Guest
Paul.
spring compressor for the rear springs...
Paul
Are they lowering springs or stock ones? If they're lowering springs, I doubt you'll need a spring compressor. :)
G
GREG@SN95
Guest
Everything is stock shit...
Will the sn95 springs and struts work on the fox?
G
GREG@SN95
Guest
Rick said:
wow, i'd really love to do one of these swaps...
me too... lol... Gonna throw on the eagle alloys, and get the ****** painted by hopefully next week... Then I got to get ready to drop in a motor... Thats gonna require some $$$$... So that goes to the bottom of the to-do list... sn95 comes first...
Paul
You can just lower the rear axle all the way down, install the springs on their perches, and raise it into place. Just play with it and you'll get it to work. If not, you can probably rent a spring compressor from the parts store. As a rule, I don't use them because they're dangerous as hell.
The SN95 struts are about 1" longer than the fox stuff, so you'll lose some bump travel. However, I don't think they'll be any immediate negative effects from installing them.
Paul.
