does this sound like a good deal?
B
ba#97
Sacramento, Ca
and also does anyone know if that canton pan will fit with the stock k member or would i have to go with another k member?
framda
Naples, Fl.
Be careful, sounds too good to be true. If it is on the up and up though, it is a good deal.
B
ba#97
Sacramento, Ca
so if it is on the up and up...what all would it need to get up and go and what kind of #'s would it put out?
Kinda hard question without details like heads. Depending on what else he gives you, shortblock is just the rotating assembly, so you'd need everything else. Intake, heads, valvecovers, ehaust, fuel system, accessory brackets, pulleys, etc.
I know I don't trust engines from CL after a few experiences. So I don't take their word, I would definitely inspect it. Look down the cylinder holes for crosshatching, no marring or glazing should be present. Make sure all pistons are the same color, ask a lot of questions, he may be able to tell you what power it put down with what heads, but again, take it for face value. I'd also pull a main and check the bearings, absolutely no copper should be visible.
Without a part # on the canton, I'm not sure. I've only seen 7qt canton road race pans, and they are tight. I'm sure you'll have to remove the factory 2 point lower brace and doubt anyone makes a 4 point lower brace that fits. It does need a special dipstick and tube, the stock dipstick hole needs to be plugged. For $800 I'd do your homework, my last $500 "25K mile shortblock" off CL lasted about 14 miles before it put a hole in the side of the block.
B
ba#97
Sacramento, Ca
ok so I'm gonna need to bring someone who knows motors more than I do with me basically. he say's it's a 9qt. i'm assuming the part number is 15-630 from what I can find on canton's site.
B
ba#97
Sacramento, Ca
I'm a serious newby here when it comes to motors so help me out with what you mean by a pull a main and check the bearings. lol.
sn95jones
Arlington, Tx
I mean in all seriousness it's not highly modified at all if I were to guess a number I'd say 300hp to the flywheel? That's just a guess.
B
ba#97
Sacramento, Ca
I've done research and it seems with the right heads and intake these can make a decent amount of power. I'm more interested in it because I was planning on doing this anyways and it'd be nice to have a track motor.
96GTPlanB
