Ok, lately I've been noticing that with the pedal to the floor the power doesn't come smooth. But if I lift off the throttle a little the power feels stronger and tons smoother. What could be wrong with it?
I would check the TPS voltages from closed to WOT. Should be a smooth progression with no flat spots. If the ECU doesn't know where the throttle is it may well feel like a fuel issue.
Also, when I'm idling ever 4-5 seconds the rpms jump from around 600-700rpm to about 1000rpm. I have stock internals though, so it's not like i have a lopey cam
is check the tps first. it COULD be fuel but then again id think youd feel this through the powerband if it was a failing fuel pump..how olds the fuel filter? and what brand and octane do you use? we did a study in school and cheaper brands i.e wally world and sheetz(places like that) carried more trash etc and stopped up the filters ALOT quicker then shell and BP(i also drove 9 hours every couple weekends and could tell a BIG difference in mileage )
and for the idle issue do the 5.0s have a IAC valve? havent ever messed with one..id check for a vac leak as well. a vac leak will cause a rough idle
I recently replaced my tps and was amazed how much better it drove after that. As they said with a voltmeter it only takes a few mins to check it out but That is where I put my money.
