Door panel help
Unless the wiring is in the way its normally a pretty easy job to slide in. Just be sure to line up the plastic clip on the bottom with the slot in the door panel and slide it down and then tuck the top in.
Jbarker83
Jbarker83
MA
On the old one the clip is in but the top clip won't stay in the door so I got a replacement and having a hard time getting the metal clip in and the plastic clip in the door feel like it needs another metal clip for that part
I am willing to bet the hold that the top slides into has worn out and will not hold it in anymore? Try a little dab of RTV on the back or some double stick tape.
Jbarker83
Jbarker83
MA
i cant get the bottom one in with the metal clip anymore idk why but i broke the tab on two different parts passenger side went in no problem
the only thing I can think of that would stop you on the driver side is the wiring. Make sure the wiring for the mirrors/locks/windows is not in the way otherwise with out pics I have no idea
