header clearance and k member
JoshM579
Hello, its me again with the 2001 gt, this forum was extremely helpful in diagnosing the running issue i had and it runs good now, however i now noticed that the steering is rubbing on the long tube headers. Looking underneath and the kmember is rusted and i can assume the engine mounts are probably at the end of their life. From what i have seen it is a common problem that can be resolved by just unbolting the steering behind the dash and forcing it slightly out of the way. I can try that but it may not be enough and at the end of the day i probably need to replace the engine mounts and should do the k member too. Does anyone have suggestions? should i just replace the engine mounts or should i do the engine mounts and k member? if so should i go with oe or aftermarket
Snorky
So. The easiest way to get the steering shaft out of the way is to remove the clamp bolt from the shaft to the rack and use a pry bar to pry the shaft straight up and off the rack.then as for supporting the engine. You will need an engine support to span the inner fenders. I nought one at harbor freight for like $80 I think. This way the engine can be supported if you drop the K member. If you are just doing motor mounts. You can probably just lift up one side of the motor. Replace the mount. If you do the K member change to a tubular setup. It is the perfect time for long tube headers.
Mikehonco69
