Drivers side window not operating
jedpony
Pittsburgh PA
Ok guys im really stumped here. The drivers window wont move up or down. So far i replaced the window switch, the window motor and regulator. I checked and power goes to everything. I cant figure out why the dang thing wont work. I checked all the fuses and no luck there either.
ram360
Pull the motor and just plug it in w/o being in the door. See if it works.
check for power behind the switches. It uses what is called a 5-wire reverse polarity system which is nice because it doesn't use relays(cheaper) but sucks because if there is a bad connection somewhere its pia to troubleshoot. Use a voltmeter and see if you have power on the back of them and if you get anything out when you push the buttons. Also check the voltage at the regulator.
J
jedpony
Pittsburgh PA
Figured it out guys. I feel like such an idiot. I didnt realize for the window motor to work the door panel connector had to be attached to complete the circuit
