e303 with stock convertor
94GTcobra
It works but you might have stalling issues here and there. Otherwise it works pretty good if you pair it up with 4.10's and a shift kit.
modo
Philadelphia, PA
LAFENATU said:
94 DropTop said:
Yes why wouldnt it?
A lot of cams won't work with a stock converter because of the amount of vaccum.
home slice what does the amount of engine vacuum have to do with the torque converter for a aod :p
aod uses line pressure and the tv cable, there is no vacuum modulator like on a c4
95-stang
94 95's have aode not aod, there's no tv cable as everythings controlled via the trans and the ecu.
The trans is very reliant on readings taken all the time including vac as far as i'm aware.
modo
Philadelphia, PA
regardless is its aod or aode there is no vacuum modulator on the trans and there is a bap which reads barometric pressure for the eec, in order to read vacuum it would need a map which there is none.
SeeYaSucker
Thanks guys, well the cam is in and it does seem to do just fine, the trans is an AODE and the car has 3.73's, no issues yet
