ecu question
94-5.0GT
im going to be installing a steeda #19 cam, 24lbs injectors, tune maf sensor for the injectors, gt40 heads, 1.7 rr but my question is do i need to do anything for my ecu? im hearing all different type of answers, some saying that i need to get ams ems, the stock should work fine, use a cobra(94&95) one, A9L(i think that it) or a custom chip. Which is probably the better one to go with? remember cheaper the better and i wont probably do anything else besides adding a 100 shot of nos. also is the ford racing extreme performance engine control system anygood?
95-stang
I use the stock ecu and use an Anderson pms, its a lot easier to set up the fuelling with a wideband too.
94 DropTop
You shouldnt need anything with that setup. If you have any questions contact addermkII i think his name is. he has tuned his car himself and is pretty experienced with the ecm's.
Addermk2
I was running my 347 on my stock computer for a long time... so if i can run that on the stock stuff, you can EASILY run a mid combo like you have posted on your stock ECM
tommybunz
i run a 351w built with my stock ecu check my sig. oh yeah sold the pms that shit sucks
