Engine braking
Tommy92
Los Angeles, CA
I noticed whenever I downshift or let off the gas, it does not slow down the car. The rpm doesn't slow down as if I kept my foot on the pedal when in actuality its off the pedal. If I downshift without rev-matching the car does slow down for a little then the rpm stops dropping and stays constant again. When I had my Mach 1, I would use engine braking and I want to find a way to get it back. I don't know if this has to do with anything, but when I put my car into neutral or push the clutch in the RPM hangs above 1300 rpm until I come to a full stop. Also, between shifts when I push the clutch in the RPM goes up slightly (~100 rpm).
I had a problem with my IAC before giving me rough idle but I got a new one and it went away so I don't know if that's the problem. Its not from Motorcraft though.
ryclef331
Your two problems are absolutely related. I would replace the IAC with a motorcraft part first and start there. You should also double check that your TPS is functioning properly. You can google how to test tps voltage and it will come up with a million search results. That should get you patched up. Your IAC isn't closing all the way due either to it malfunctioning and sticking OR something is telling it to remain open (TPS).
I thought ford put that in their ECU strategy. Can't remember the term, but in a nutshell it was a hanging idle on the manual cars.
ryclef331
True. Its called the "dashpot funtction" and it allows a slight "hang" but its merely there to assist with smother shifting with the stick cars however...it shouldn't "hang." to the extent he and many others describe. If its idling high at stop lights, slow to return to a normal idle, and acting as if cruise control is on, its a malfunction.
Yea, mine will idle high until I come to a stop.
Even if I clutch at 60mph, it will still idle a little higher.
CC'S95GT
Hampton ,Ga.
Sometimes. I have 4:10 gears so my rpm's run higher. But if I put it in neutral and coasted to a stop the rpm's would hang about 1000-1200 rpm's. Sometimes it would come down slowlyon it's own, sometimes bliping the throttle would bring it down , sometime nothing would.
I pulled it off and ran a restistance ck on it and found a dead spot near the idle position. You can also ck it installed by back pining the connector.
If using a digital volt/ohm meter make sure you move the throttle very slowly or you may miss the dead spot. Once you find something repeat the test amd make sure the dead spot is in the same location every time,
T
Tommy92
Los Angeles, CA
I have warranty on my IAC so I'll exchange that with a Motorcraft IAC and if that doesn't work I'll take a look at the TPS. Thanks!
T
Tommy92
Los Angeles, CA
Case closed. I picked up a Motorcraft IAC and installed it today. No more rpm rushing up between shifts and comes down smoothly when I come to a stop. Also got my engine braking back. Thanks everyone!
marktuck99
