I have a 95 gt it has ported gt40x heads 1.72 roller rockers b303 cam cobra upper and lower intake and 65mm throttle body and is skipping at low rpms I have changed coil, plugs, wires, cap, rotor button, injectors, distributer, tfi or whatever its called on the pass fender well, injector wiring harness, maf, iac and tps. Im stumped it started before I swapped the heads it only skipped when it was cold and stopped know it does it all the time at low rpms when I get on it it smoothes out it has new push rods and lifters aswell and not making any noises at all just skipping. Any help would be greatly appreciated. Thanks Craig
