engine weight/ what stand to use?
how much does a 2000 4.6 windsor engine weigh? or what weight rated engine stand should i use? will i be ok with a 750lb engine stand or do i need something sturdier?
JerZeyStangz
Northern NJ
That is definitely plenty because the 03 Cobra motor is 650+ and that has M112 Supercharger, and Iron block with 4v heads, the 2v shouldn't be that heavy at all.
BOS-94-003
MustangChris said:
i built my own out of popcicle sticks and rubber bankds.
I dont know who has the highest post count or oldest member but you, by far, hold the record of posting in every post on this forum.
highest count: probably rick focks
oldest member: probably matt
posting in every thread: no. lol.
i dont post anything at all in the 5.0 section... just read it to try and learn something...
i also rarely post in the 18+ section, the 3.8 section, the SVT section, ... etc. etc.etc. lol.
also, alot of the threads i fill with garbage happen to be simple 1 answer question threads and no one reads past the first 2 posts.
Paul said:
750 is plenty.
what more needs to be said?
i just try to add a little humor so when you read to the bottom of the thread at least you get a punchline instead of nothing. :)
