exhaust help
All_Ford_Fun
Ok , so im alittle lost here! Ive got a bone stock 95 gt and im tired of it sounding like a V6!!! Its time to make this thing rumble a bit.
so theres a local guy selling a borla exhaust system , litle diffrent than what im personally use to. its more of a truck looking exhaust to me
like true duals , but its only $200 but its off a 4.6 and i have a 5.0 , will it fit? the seller ofcourse says it will... also ive been told a fox h/x pipe will fit sn95's , is this true aswell? thanx
ivan12
The midpipe from the 96+ will not "bolt" on. I believe it's the passenger side flange that connects to the headers is flat. I'm not sure if a muffler shop can make it work or not. Some of the fox mid pipes work on the sn95 but there's a small tube that is in a different position.
The catback should still fit your car, if it's off a 98+ the only thing you have to change is the tip hangers.
As far as midpipes go get the correct one for your year.
ivan12
That "should" work on your car the way it is now. +1 on what onyx said, get the right year midpipe. If you want a good rumble though get an off road mid
