F.I. To carb swap
94 DropTop
Im doing a carb swap on my 94 where can I find a good how to? I tryed searching and could find anything.
carbed94
well im not sure ive ever seen a how to on goin efi to carb...but is pretty simple imo...just start with the basics like intake carb dist. fuel setup ive done it to my 94 and ive just about got every thing like i want it ....if its nice tom. ill try to get some picks of mine on here...hope this helps if ya got any questions ill help the best i can ...lol
94 DropTop
ya anything you have to hel would be awsome. i want to carb the 302 and put a c4 in it. Just a parts list would be nice on things i woud need. I know the basics like intake, carb, taking out the wiring. But like how much wiring do i take out cuz i want all the power windows and top to still work. How will i make it so the guages still work? What things will i need for the tranny swap. I dont plan on doing this asap i plan on starting towards the end of the summer and tinkering with it all winter. i would also like to make my project a how to for everybody. I know its pretty basic but there are always road bumps. What size carb would you recommend? 650?
carbed94
well a far a wiring everything under the hood that has to do with fi can go... but your stock gauges all mine work but the tach..and what i done was traced the temp wire and oil psi and all those things an left them hooked up stock and i read u have to leave the comp in it to get the gauges to work but i havent takin mine out to see if u need it or not...and i would go with a 600 dp or a 650 dp if your goin with cast heads and stock bottom 302 thats ALL u need dont listen to some redneck tellin u need a 750 and go with a tfs1 or a b cam for best perfomance with a carb setup....(fuel system)and u will either have to sump your stock tank or just put a cell in it , and go with a holley blue pump and reg. it to 6 psi and run 8an line from tank to reg. then out of both sides of the reg to the carb run 6an...
94 DropTop
where did you hide all you wiring? Will the stock tranny work fine with the car being carb or do i need to find a solution for that to.
Mr. OAM
Always the first place to start out on this project....
http://www.jason.fletcher.net/
A 600 will do fine. Go with vacuum secondaries with the auto trans. The car won't bog when you mash the pedal from a stop and it will open the secondaries when the engine is ready for it. The mechanical secondaries are best on a manual trans when you would lose the vacuum drop to open the seondaries while shifting.
For reference the 289 Hi Po used a 578 CFM carb.
Steve
ScottyDsntKnow
To do the swap
-aeromotive carburator swap regulator
-Ignition box
-Rewire the guages(easier to just do a full autometer dash if you have the money)
-1985 GT distributor
-Cowl hood or drop mounts to clear the intake/carb
And of course the intake/carb/air cleaner.
If you don't want to use the aeromotive swap regulator then you have to run new fuel lines and get a new pick up and pump.
Willautoy
I'm doin a carb swap on my 95 this weekend,personally replace the fuel line and run the inline pump/reg assy. Just think what would happen if the efi swap regulator sticks and allows full pressure to the carb. Grab the weenies and marshmellows! Besides if you read the instructions on the regulator you have to install a larger return line anyway.Good luck and happy HP gain.
carbed94
if your goin with a c4 with a stall u want a dp thats all ive ever run and they make more power than the vac....ive been workin to dark so i havent had a chance to take some pics.....and dont even try that efi to carb reg bs i already tried that and it aint worth a shit....i just went through all this crap like 3 months ago ...lol
94 DropTop
well found a way i could keep the AODE so im going to stick with it for awhile. thanks ill look at the link. thanks for all this help guys i cant wait
