flexplate options..
forcefedhatch
well i had purchased my torque converter froma buddy of mine brand new for my aode, well what i didnt take into account is that its a 10.5 bolt circle and the 94-95 gt's have the 11.4 so does anyone know of any options i have for either buying a new flexplate with the proper teeth and counter weighting WITH THE 10.5" bolt spacing.. or should i just have mine drilled, im kinda scared to do that because if its off even a hair it could be catastrophic... or if anyone knows for sure of a flexplate that will work..someone said the flexplate from a lincoln mark viii but, not sure if its the 5.0 and if its the 10.5 converter bolt pattern... ANY HELP wold be great im trying to get this thing on the dyno to get tuned with the boost!
forcefedhatch
forcefedhatch
is the 94-95 flexplate 157 tooth or 164 tooth cause i cant find an 50oz imbalance 164 tooth flexplate with a 10.5" converter spacing...
forcefedhatch
forcefedhatch
ok awesome i have a message in to coan racing part# coa-63635
description (SFI APPROVED FLEXPLATE, SB, w/50 OZ-IN WT, 164T, GM 10 3/4 BC AND C-4 10 1/2 BC)
i think it should work since it has the 10.5 bolt circle... unless anyone else can find a flexplate that will work with the aode and have a 10.5" torque converter bolt circle
