Flywheel during clutch replacement
Flade
Niceville, FL
Just pulled the tranny to swap the clutch on my wife’s 98 GT. The clutch is shot, but the fly wheel is nice and smooth with no grooves. You can still see a bit of the swirl marks from when it was originally turned. None of the auto shops around here turn flywheels any more and they don’t stock them for this car either. They seem to only be special order. I can order one from summit, NPD, or LMR, but I wanted to finish up this weekend.
Can I just clean the flywheel and use it as is? Do I need to roughen it up a bit so the clutch grabs better? Do I wait until Mon and see if a trans shop or Machine shop is open To get it turned, or do I just go ahead and order a new one?
What‘s the current thinking for these?
Discolored hot spots, usually raised and can be felt rubbing your fingers over them. If you feal raised bumps, itll need to be ground.
The judgement call is yours. If it were me, id wait to get it done right, considering i just spent the coin replacing a toasted clutch....may as well do it all up right and be prepared to go another 100k miles
DKblue98GT
17x9 &10.5 with 255/40/17 and 315/35/17
Sent from my Pixel 2 using Tapatalk
F
Flade
Niceville, FL
Perfect, those are exactly the rim sizes I have (American Muscle Bullit rims). And it’s the loo’ I am going for. I’m planning the 315/35/17 on the rear, wasn’t sure what size for the front. Now I know.
DKblue98GT
I just realized in that pic the car has 275/40/17 in the front. I put FR500"s on it a few years ago...
F
Flade
Niceville, FL
Back to the original issue, the decision turned out to be easy
Seems the flywheel has Hairline cracks.
ecbb2402-3ab9-4a71-a5f6-54cbc4174d7c-jpeg.793235
So now where to find a replacement
LMR has th Ford Performance Flywheel for $295
Summit has McLeod for $280
Summit also has Fidanza Nodular Iron Flywheel for $173.
I assume the Ford one is good. Does anyone have experience with the Fidenza flywheels? The claim to be better than the OEM.
F
Flade
Niceville, FL
Paladin1001
Echoing here, yes you need a flywheel. I got a smokin' deal through Amazon on a Ford Racing one when I did my daughter's 98 GT. I had ordered one through Summit but I cancelled it when I found it cheaper through Amazon. I called them to see if they could match it and they couldn't. I don't remember how much I paid but it was way cheaper than anywhere else.
F
Flade
Niceville, FL
Mines at the machine shop today. We’ll see what they say after getting into it. If it’s bad, then I’ll get the Ford Performance one from Summitt
joe65
yes fidanza is a good brand. been around for a long time and their flywheels are known to be good.
Daryl
SoCal
To finalize my recent 347 stroker build, I had a McCloud clutch and 23-tooth steel flywheel (more streetable than aluminum) installed. Seemed silly to install basically a new motor with inferior clutch/flywheel.
Just my unsolicited $.02!!
on edit: I saw AFTER I posted that you were able to get the flywheel turned. Good on ya! Should be fine. And, FWIW, I’m also running FR500 17x9/10.5’s with 275/40 and 315/35’s on my ‘95 Cobra.
F
Flade
Niceville, FL
Thanks!
Juan4480
