fog light removal, 94 vert
94opalgt
putting a cobra front bumper and fog lights on my 94 vert. now, on the passenger side of the car it had this big black #25 weight that goes from the back of the fog light assembly to a brace on the frame rail. i got the weight off, cant figure out what it's for, but i can't get the fog assembly off to put the cobra one on.
anybody else have this problem? anybody tel me how to get this thing off? :TY:
SoddyRebel
i did the same swap, mine just had 2 bolts on each bracket, maybe take a pic of it and i can help.
Win
Kennesaw, Ga
if i remember correctly the vert has a weight in the passenger fender and when taken off it wont cause any misfortune... this is just what i read i never did it on my 95 vert
94opalgt
the coupes are different than the verts.
i'm trying to get the stock bracket off. it don't have bolts like the drivers side does, it's got 2 studs that go through the bracket. one has a 13mm nut on it, i got that off. the other has what looks to be a washer threaded on it, thats what i can't get off. any help?
945LSTANG
sounds like it could be a rivet. if so you would have to drill it out.
im in the same boat as soddy, i had two or three bolts holding my fog lights in.
94opalgt
got it, there is a bolt on the inside of the bumper support. you have to remove the styro foam inside to get to it.
