FOULING PLUGS AFTER INJECTOR UPGRADE, NEED HELP!!!
punksable
OK SO I INSTALLED SOME 24# INJECTORS TODAY WITH A 1" GT 40 SPACER, I ALSO PUT A NEW TUBE IN MY C&L FOR THE 24'S. I THEN BLOCKED OFF THE EGR AND PUT A SIMULATOR IN PLACE. THE CAR STARTED JUST FINE SO I TOOK IT FOR A DRIVE TO LET THE COMPUTER GET ALL HAPPY AFTER HAVING THE BATTERY DISCONECTED. I DROVE ABOUT EIGHT MILES BUT NEVER REALLY GOT ON IT BECAUSE THE ROADS WERE ALL WET. SO I GOT ABOUT A MILE FROM MY HOUSE AND THE ROADS WERE DRY AND I STARTED GETTING ON IT, WHEN I GOT TO THIRD I HEARD A SLIGHT POP AND THEN IT FELT LIKE IT WAS DOWN A CYLINDER, THEN I HAD SMOKE COMING OUT THE EXAUST SO I WENT HOME TO FIGURE OUT WHAT THE HELL I DID THIS TIME. I NEVER GOT A CHECK ENGINE LIGHT ALSO.
SO I LET THE CAR COOL DOWN AND STARTED PULLING PLUGS AND FOUND ONE OF THEM FOULED, SO I DECIED TO DO A TUNE UP WITH NEW PLUGS AND CAP, ROTOR BUTTON. AFTER I PUT THEM IN I TOOK IT UP THE ROAD ABOUT A MILE AND IT SEEMS TO RUN FINE BUT I REALLY DONT KNOW WHAT TO SET THE FUEL PRESSURE REGULATOR AT, I HAD IT SET ON 38 PSI FOR THE 19# BUT NEVER CHANGED TO FOR THE 24'S AND I THINK THAT IS WHY IT FOULED A PLUG. I AM TRYING TO FIND OUT WHAT TO SET IT AT TO BE SAFE AND NOT RUN LEAN OR TOO RICH.
Stangbangin
fwiw fuel injectors are rated at 39 psi I believe. Make sure all the plugs are getting fire.
95-stang
I was running at about 38, with 24lb, but it seemed to run better at 32, no idea why.
vettekiller3
ya id try hotter plugs and maybe open the gap alittle what is your plug gap at now and what is ur fuel pressure at
ryclef331
I never liked C&L maf's HOWEVER, you might try "clocking" the maf 1/4 turn at a time to see if you notice any improvement. they are rather touchy to how they read the incoming air.
