fox TB swap, hood clearance issues.
94opalgt
anyone else have this problem? the tube that stick off the top of the TB hit'sthe hood before it closes.
anything i can do, or do i need to just buy a cobra R hood?
Paul
Had the same problem.
Either install dropped solid motor mounts, or buy a new hood.
94opalgt
just put new motor mounts in, energy suspension. i guess i need to get a new hood.
thanks
Magic
Some time zone
is that the tube for the vent tube from the valve covers?
Why not remove it, plug the hole and hook the vent tube up to the air intake tube??
Better than buying a new hood just for that IMO.
Paul
It's a lot cheaper to just buy an elbow and the correct throttle body.
1slow46
he just bought the stuff for a fox setup, why go buy new stuff, unless theres a different fox throttle body that will fit..but i assume your talking about buying the 94/95 stuff
Paul
An SN95 elbow and throttle body can be had for dirt cheap, especially used. I just sold my 70mm SN throttle body for $50, and sold my last elbow for $60. That's a lot cheaper than a $5-600 hood plus paint.
Oh, and welcome to SN95 forums. You should go introduce yourself.
Paul.
94opalgt
i already have all that, and don't want to use it. fox style cleans up the engine bay a bit, and has better throttle response with out all the bends in the intake tube.. i'm trying to find solid motor mounts now. all we can find at summit are ones for the fox car's and i'm not sure if they will work.
94opalgt
hey, your car is an 03, what the hell are you doing here charles? you think you can go wherever you want to just cuz you got a twin turbo car? LOL.
1slow46
thats some funny chit there...ROFLMAO
94opalgt
where did you get your dropped solid mount's at? the fox one's iwas looking at said they raise the motor 1 1/2 inches?
Paul
I agree, the fox does clean it up a bit. I had to use it because they don't make big throttle bodies for SN95s. I didn't notice any real difference in throttle response though. That has a lot more to do with tune than it does the throttle body setup.
Here's the drop solid mounts.
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000081a~Z5Z5Z597158~P86.95~~~~~~~F
Paul.
davidnc
Did you turn the vent tube to face the rear. That gave me an extra inch of clearance.
94opalgt
did that last night with a screw driver. stuck it in the end and spun it around, now the hood closes.
can't really tell yet exactly howe much clearance i have under there. i'm gonna check it with a clay bar tonite.
and paul, thanks for the link.
Paul
No problem. Let us know how it goes. I'm the undisputed heavyweight king of figuring out how to make hoods clear. I managed to get my old 418W under a stock '98 Cobra hood with two 3/8" phenolic spacers and a nitrous plate. :) Holy crap it was a lot of work though.
Paul.
94opalgt
Paul.
you're the man then if you got that to fit. i'll post some progress and finished project pics when done.
Paul
It was a bitch. If I had to do it over again, I'd probably just buy a new hood. I just REALLY love '98 Cobra hoods. Alot.
Magic
Some time zone
Paul.
Paul, which intake did you use with your 418? I seem to recall a TFS R?
For me, the way I look at it is, is Saleen could stuff a 351W with a foxstyle throttle body setup under a stock hood of some S351 cars, then its no big deal with a 302 and a fox throttle body setup.
Paul
Yep, Windsors actually fit pretty easily as long as you don't go nuts with phenolic spacers and nitrous plates and whatnot. :)
My new setup uses a TFS-R. My old setup was an Edelbrock Performer RPM.
If you use aftermarket fuel rails, it can be a PIA to fit some aftermarket intakes. I actually milled out the entire underside of my TFS-R (where the vacuum ports are) and had it welded back up so I could use it on my new motor without phenolic spacers.
My upper intake has about 100 hours of various work in it, and about $1000 to make it look the way it does. There is a ridiculous amount of milling, cutting, sanding, welding, polishing, and chrome plating that went into it.
It fits under a stock hood too! Except the throttle body and 4" inlet pipe doesn't. :(
Paul.
