Front Calipers little loose?
jys97cobra
I juss got new pads cause my old ones were really loose and made the caliper rattle. the new pads made the caliper tighter but there still is some play and noticable noise over bumps, is there supposed to be some type of shims on the bracket or pads?
reivaxtorres
there are shims on the bads, but what do you mean the caliper is loose? its not supposed to have any play in it, no movement that you should be able to notice
94pacecar435
i had the same problem 2 weeks ago. u forgot to put the little metal bracket that comes with the new brake pads. they mount on the brake pad itself. just look at ur old pads and you'll see what i mean.
Mustanger
Southern Oregon
Caipers being loose would be a serious problem...pads being loose not much...you just left out the shims or little springs that keep the pads tighter.
J
jys97cobra
the calipers have noticable play and i didnt get any shims with the pads. the pads are tightly pressed into the calipers but the caliper with the pads moves up and down like a mm or 2. i need to know if the caliper bracket where the pads sit have any shims. i bought brembo pads not factory
J
jys97cobra
can someone send me a pic of the caliper bracket to pad matting . this is a serious problem, the previous pads from all the rattling finally seperated from the shim in back and caliper moved soo much i had to press the brake more than half way to finally feel it stop
