Front Control Arm Bushing Removal
sleepn_sn95
Indy
Over the winter I'm building up a set of stock control arms to swap onto the car. I've got Prothane poly bushings, shorter end links, and will be going with Steeda x2 ball joints. I've researched and couldn't find a whole lot of info on removing the stock front control arm bushings. I don't have the means to burn them out really. I've seen where people have drilled holes all around the bushing and was able to get it out that way. Any tips or advice on doing this?
Tally_4.6
More well known than you
Clermont, Fl
All you have to do is pry the inner cage out with the bushing. I made the mistake of not realizing i could do it, so i started one with a blow torch and filled the whole shop with burning rubber smoke.
You can't reuse the cage with the prothane poly bushings, takes a few minutes for each.
sleepn_sn95
sleepn_sn95
Indy
What do you mean by inner cages? The sleeve the bolt goes through? These are what I bought, without the outer shells
http://www.maximummotorsports.com/Front-Control-Arm-Urethane-Bushings-1996-01-GT-Std-P408.aspx
Tally_4.6
Clermont, Fl
Well the arms I had were non cobra arms I'm pretty sure. There is the arm, the outer cage, then the inner cage, then the bushing. Let me see if I can find a pic
Tha trap house.
Tally_4.6
Clermont, Fl
That's the outer cage, picture a bushing inside that with another cage around it.
Tha trap house.
Staff member
I used the drill bit method. Drilled a bunch of holes all the way around the bushing then you could use a saws-all or something to cut what the bit didn't get. Then I used a wire wheel on a drill to clean the left over rubber off of the metal sleeve. I'm pretty sure the bushings I had re-used the metal sleeve that the old bushing was in. I could be wrong though, it's been a few years since I did mine.
I also have used the drill bit method. It worked, but I also did break one bit so I would not recomend using your titanium nitride bits to do this
sleepn_sn95
sleepn_sn95
Indy
Got the bushings most of the way out today. Used the drill method and took me about an hour to get all 4 out. I still need to figure out how to get the rest of the rubber out then they are off to get blasted
evilcw311
Most Evil Member!
Louisville, KY
I wire wheeled mine with the assisting of a propane torch. Stinks to high hell but gets it done.
it occurred to me that they would probably come out easier with the drill bit if after you first stick it in by spraying some WD40 down the drill bit. Seems like it would coat the inside of the bushing and make the rubber slide out 10x easier?
evilcw311
Most Evil Member!
Louisville, KY
Problem is bushings pretty much glue themselves to the casing over time
sleepn_sn95
sleepn_sn95
Indy
Wire wheel took care of it no problem, just needed a pretty small one to get inside the smaller hole. Spraying a little pb blasted in there also helped eat away the little amount left over after that and they cleaned up really well
Correct but after working the drill around it one time it is broke loose and the only thing holding it in then is the friction between the rubber and metal or the rubber on the metal against the rubber. I bet a little oil would go a long way to make it easier.
