FRPP Supercharger install kit???
J
joelbegt
Guest
Ive been searching the net alot and can't find out what comes in this kit. thatd be great if someone could tell me what is included in the kit.
thx
joel
Thomas_W
Capon Bridge, WV
Fuel pump
Fuel Rail crossover fuel lines
Fuel injectors
upper radiator hose
Heater core hose
Alt. Relocation brackets
Computer (throw it in the trash, the tune sucks)
IAC hose
Throttle Cable Bracket
J
joelbegt
Guest
thx for the info. 1200 bucks sounds a bit steep for an install kit, esecially since the tune isnt worth much. im looking at supercharging and was looking for tips on what brand to go with. i've heard a few horror and good stories with every brand. what would you guys suggest? i work at a machine shop so custom brackets and so on wont be as big a challenge for me. the cheapest frpp charger i can find is around 2400 bucks, which doesnt sound to hateful. does that sound about right?
nesqwick_05
Thomas_W said:
Fuel pump
Fuel injectors
upper radiator hose
Heater core hose
IAC hose
hmm anything in there that you cant get out side the kit? i mean, i could get injectors and radiator hose, heater cor hose, IAC hose and other stuff elsewhere correct? or is it just cheaper to shell out the money?
Here's an official parts list for the install kit (1998 Manual tranny):
Alternator mounting spacer
Water outlet washer (2)
Alternator mounting bracket
Heater bypass hose clamp (2)
PCV molded exit hose
Upper radiator hose
Thermostat
Fuel rail crosssover hose-rear
Fuel rail crosssover hose-front
Water bypass hose-heater inlet
Clamp-fuel rail crossover (4)
Idle speed control inlet hose
EVR solenoid mounting bracket
Vacuum harness
Throttle cable bracket
Fuel rail-right side
Alternator shake brace
Oversize alternator pulley
Modified coil mount bracket
Engine management processor
Alternator idler pulley
FEAD drive belt
Fuel pump kit
Fuel Injectors (8)
Instruction manual
EGR valve gasket
Idle speed control gasket
Throttle body gasket
water fill plug
DPFE transducer mounting bracket
EPATS module (must be matched to PCM)
Bolt-5mm X 22mm gold (2)
Bolt-6mm X 12mm silver (2)
Bolt-8mm X 35mm black (2)
Nut-8mm silver (2)
Bolt-8mm X 23mm silver (2)
Bolt-8mm X 80mm gold (2)
Washer-alternator idler
9psi 98
sanchezcruz_20 said:
That smiley face with the shades is supposed to be the number "8"...haha
8 30# injectors to be correct.... also the kit includes a passive anti theft box to go with the ECU.
