fuel issue
ProjectMongoose
First I'll tell you the complete list of mods. its a 302 bored 30 over (306) with forged crack rods and pistons (according to the seller) has a f303 cam stock e7 heads stock intake upper and lower with a K&N filter BBK fuel pressure reg. with gage attached to it. The transmission feels new shifts are firm and easy to shift and has a pro 5.0 short throw shifter with a cobra clutch. has 3.55 rear gears and eibach springs. BBK shorties with BBk o/r x-pipe and some crazy mufflers that dump.
The issue I am have has me dumb founded cause i dont wanna waste money on a part if it does need to be replace. As the car is idleing im watching the fuel pressure gauge and its at 47 psi....then it drops down to 28 and picks back up. its not constent and its not in a timely manner. one second its fine two min later it drops. I put my ear to the gas tank and i can hear the fuel pump cutting off and on. As it comes back on i can hear the whine pick up slow but goes to the point of optium operation. But then cuts off and back on. I did the paper clip trick to find the codes for the car cause the check engine light is on and i got EGR and smog pump. Off course both are disconnected or not there. I need to know if this is the fuel pump soon to go completely out or is it something else i need to look at.
Thanks for all the help and Im glad i found a forum site for these mustangs i love the most.
Project Mongoose
John
95opal
Did you pull the vac line off to read the pressure?
P
ProjectMongoose
i did pull the vac line off and the fuel pressure reads 47 does the same thing as mentioned you can hear the fuel pump shuttin off and watch the pressure of course drop but once the fuel kicks back on the pressure goes to 47.
P
ProjectMongoose
For those wondering, it was the fuel pump. I disconnected the inertia switch in the trunk and ran wires from the plug to the battery and watched the pressure gauge. took about a min and started to fall. so i droped the tank and replaced the pump and it took me about 3 hours to do everything mainly because i was doin it myself but from start to finish three hours. now that i got that fixed i have a few other issues i need to deal with before i can really roast some tires
