Fuel pressure regulator
J_lope82
South Texas
I am wondering if installing a aftermarket adjustable fuel pressure regulator would add a little more horsepower? Or what benefits I would get with installing one? Current mods are full PI swap, tune and exhaust. In the future I want to do cams and gears. I don’t plan on going wild with the mods.
Staff member
Fuel pressure regulator will not add power. You’re not at the limit of your fuel injectors or your pump, so there’s no need to change it. The regulator would only be needed if you outgrew the fuel rails, added aftermarket rails, and needed a way to regulate it.
Sometimes, if you are borderline on an injector, you can increase pressure to flow them a little more, but you don’t need that. If you bump pressure now, it’ll throw your tune off.
white95
Apex Junky
Prairieville, LA
You could install aftermarket rails, regulator and such. As long as you leave the base fuel pressure the same it won’t cause any issues. Furthermore, my buddy nearly lost his ride when the stock rail crossover line burst. You could always do this in the name of a safety update.
