fuel presure settings?
dwight97
on my 97 gt i put pi cams/intake and underdrive pulleys and a fenderwell cai. has had the back cats removed front are still there runnin 3 73 gears...well with 26x10 slicks it dies on launch i dont have a fuel gauge but i got a adjustable regulator and i turned it till it was flooded out a lil and it solved the problem doesnt die on me or nothing ne more just its flloding real bad and im scared to move it cause its runnin good now...any ideas to set it on? and racing fuel what kind would be good for it? leaded or unleaded 110?
9psi 98
What injectors are you running. That will have a lot to do with what pressure you can run. Even if you don't get a gauge inside the car with you, at least mount one on the fuel rail so you have some sort of idea what's going on. Get some more info and we'll be able to help you out more.
