Fuel pump assistance
Blakonblak94
So I can get my hands on a Walbro gss317 255lph for cheap. Its supposed to fit a 96-97 cobra, but what reason would keep me from using it on my 94 gt? I know the only difference is the size of the inlet, but other than that any reason?
toyman
IIRC the GSS317 is not a high pressure unit. I believe it's intended to be used on systems without the return fuel line. You want the GSS340.
Blakonblak94
Blakonblak94
Correct not high pressure. So it will not work? Im asking because I can get it at a cheap price brand new.
Blakonblak94
Blakonblak94
Sorry to bump, but it doesn't seem like it'll make a terribly huge difference since the car won't be seeing over 39psi for right now. From reading it seems the difference is when the pressure is around 50-60 psi.
toyman
What's the good price? The GSS340 runs about $100. I would be concerned with the regulator maintaining proper pressure to the injectors with a pump that's not delivering fuel at 70+ psi to the regulator.
Blakonblak94
Blakonblak94
its the gss317, I know its not on there, but I'm using the 255lph standard as the reference for it. It came in a 2000-2004 vortech kit and the guy is getting rid of it cheap. I've referenced the number and it seems that the gss317 is for 96-97 cobras. These also have a return style fuel system if I'm thinking right, which is what the 94-95's run correct? I'm willing to try it because I dont see an issue with it not having enough flow.
