Oct 10, 2011 #1 MustangChris Mythic Level Joined Aug 20, 2008 Messages 27,282 Reaction score 951 Location Aurora, CO I have two walbros in the tank. what size fuses should I use on them? (they are individually powered) many thanks, Chris
Oct 11, 2011 #2 ttocs Forum's #1 poster Joined Oct 9, 2009 Messages 37,641 Reaction score 7,760 Location Evansville Indiana do they list a max amp rating?
Oct 11, 2011 #3 OP OP MustangChris Mythic Level Joined Aug 20, 2008 Messages 27,282 Reaction score 951 Location Aurora, CO i didnt install them. I traded a 302 alternator bracket to my performance shop to install them for free. lol. i just brought a tank in, and left with a tank with the pumps inside.
Oct 11, 2011 #4 97stanger Legend Joined Mar 22, 2006 Messages 5,880 Reaction score 100 I also run dual walbros, off the top of my head I'm running dual 30 amp relays with 15 amp fuses, but I'll double check for ya
Oct 11, 2011 #5 ttocs Forum's #1 poster Joined Oct 9, 2009 Messages 37,641 Reaction score 7,760 Location Evansville Indiana with out knowing which pumps are in there it will be hard to recomend a good fuse size.
Oct 12, 2011 #6 OP OP MustangChris Mythic Level Joined Aug 20, 2008 Messages 27,282 Reaction score 951 Location Aurora, CO thanks 97stanger. slapped 15a in there and they run fine. started my car for the first time in roughly 24 months last night. tuner at the shop suggested a 30a fuse, he said 15a will blow the minute we push the car... but i dono about that. :-/ anyways. thanks again everyone for your input. -Chris
Oct 12, 2011 #7 97stanger Legend Joined Mar 22, 2006 Messages 5,880 Reaction score 100 glad to hear it all worked out, good luck with it!
Oct 12, 2011 #8 ttocs Forum's #1 poster Joined Oct 9, 2009 Messages 37,641 Reaction score 7,760 Location Evansville Indiana keep a 20 with you just in case it should happen to blow but only one way to find out. I am about to install a holley 255 lph pump, will I need to swap mine out?
Oct 12, 2011 #9 vermilion Legend Joined Sep 15, 2007 Messages 6,297 Reaction score 164 Location maryland stock fuel pump relay is a 30a and fuse is a 20 amp. if you are running dual you can add the existing wiring but with a 30a circuit breaker.
