Fuel Pump Fuse Questions
MustangChris
Aurora, CO
I have two walbros in the tank.
what size fuses should I use on them? (they are individually powered)
many thanks,
Chris
MustangChris
MustangChris
Aurora, CO
i didnt install them. I traded a 302 alternator bracket to my performance shop to install them for free. lol. i just brought a tank in, and left with a tank with the pumps inside.
97stanger
I also run dual walbros, off the top of my head I'm running dual 30 amp relays with 15 amp fuses, but I'll double check for ya
MustangChris
MustangChris
Aurora, CO
thanks 97stanger.
slapped 15a in there and they run fine. started my car for the first time in roughly 24 months last night.
tuner at the shop suggested a 30a fuse, he said 15a will blow the minute we push the car... but i dono about that. :-/
anyways. thanks again everyone for your input.
-Chris
keep a 20 with you just in case it should happen to blow but only one way to find out.
I am about to install a holley 255 lph pump, will I need to swap mine out?
vermilion
maryland
stock fuel pump relay is a 30a and fuse is a 20 amp. if you are running dual you can add the existing wiring but with a 30a circuit breaker.
