Fuel Pump
Cal35
Lincoln Nebraska
my car currently has a cai, longtubes, uderdrivepulleys, 70mm throttle body and trick flow street burner intake manifold upper and lower, cast iron ported gt40s with 1.7 rocker arms and trick flow upgraded springs. I also upgraded the fuel injectors to 24lb injectors. do I need to upgrade the fuel pump? and if so could you point me in the right direction. thanks.
and btw I have not driven my car yet I am installing the heads as we speak. just wanted to know if I will be alright after I am put back together.
RichV
CO
I think you'd be fine. But you'll know when you put it on the dyno for a tune.
