Fuel Trouble i think...
cooper1320
Every now and then my car will not start, it culd be working fine, then i stop somewere turn off the car and when i fgo back to turn it on it does'nt turn on, i know its not the started or alt, or the bat. it sound like it does'nt have gas, and also sometimes it will like sputer when im taking off in 1st, like vroommmmmm..m..m..m.mmm.m.m.m.m.m.m.mmmmmmmmm, u get me lol
and also if i floor it as sonn as i get ovet 3000 rpms it will sputer and start to back fire.
i guess its fuel injectors, maybe my o2 senors also, but not sure
has anyone had this problem or does u know what i can do to fix it
prstang
Sounds like the stator inside the distributor is going bad. Not an expensive fix!
LAFENATU
Ford fuel injectors don't go bad lol.
Start with the fuel filter....replace it and see if that is it - all your symptoms could actually be that.
The stator could be the problem but I think it is more like the ignition module not the wheel.
Stalling is typically the ignition module but breaking up at higher speeds.... - is the tach jumping up and down when it is breaking up?
-R
C
cooper1320
-R
didnt know that about the injectors, my bad
i've already change the fuel filter, and yea some time its will surge, like the tach jumps, and some time the lights get brighter
LAFENATU
Well the injectors could go bad, I didn't mean it was impossible but you very RARELY ever see Ford injectors go bad. They are great pieces.
Try the ignition module, I am thinking it is that. If yours is the original, it won't hurt to replace it anyways.
