Fuel
2broke2gofast
Putting a supercharger or nitrous on over the winter. I've got AFR165 heads and all the other bolt on stuff. Will 30lb injectors be sufficient? Also, what kind of boost should I look for a stock bottom end car to hold under reliably...Thanks
stang4u2nv
#30 injector will be more than enough if you plan on using nitrous, if you plan on using boost then you need 42 lbs squirters, as for stock bottom end on boost, it all depends on the tune you have in the car, this is the critical most important fact....i have seen 14 psi on a turbo notch and it's doing great but i would do 9-10 psi just to be safe.
Staff online
