gears
forcefedhatch
Same here! Posi, axle bearings and seals, full or nothing unless you have done a rebuild recently..
Sent from my iPhone
Musturd
Exactly.. Do it once and do it right... Gears are a easy thing to fuck up pinion preload all that is key back lash etc , you can just throw gears in and hope they work lol... Pay the 500 you won't regret it
Slykin
Tyler, Texas
I don't really want to derail this thread from the OP's question... but if (when off the ground) both rear tires turn in the same direction when spun by hand, is the diff completely shot? And also, if there is play where the u-joint connects to the rear end, and also play between each wheel, are the gears in need of adjustment?
Slykin
Tyler, Texas
I thought with an LSD they went in opposite directions when turned by hand in neutral... That's what my vert did.
RevJon
