http://www.granatellimotorsports.com/catalog/Ford_Suspension-27-2.html
I'm considering changing up my rear susp setup on my 94GT. I'm putting this add up as a feeler. I still have the stuff on my car however if it sells I will pull it off. Please understand you may have to give me a few days to get them out to you because of this. Keep in miind it is USED but in good working condition. I'm looking for $300 plus shipping for the Uppers and Lowers. Cost $450 new for the pair. I can get some pics of the actual parts if needed but they are still on the car so it's kind of difficult. Some info on the parts from the granatelli website is listed below.
1979-2004 Mustang Rear Lower Control Arms (w/ weight jacker)
Product ID : GM-CA7998WJ
$245.00
1979-2004 Mustang Rear Upper Adjustable Control Arms
Product ID : GM-CA7900U
$199.00
$245.00
- Fits 1979-2004 Mustang w/o independent rear suspension
- Direct OEM replacement
- Eliminate flex, control wheel hop, improve traction
- Weight jacker model allows driver to lower rear end 1" or raise it 2" from stock
- Weight jacker model is ideal for extra drag tire clearance or adjustability at each corner
- HD tubular steel w/precision welds
- Durable powder coated finish
- Installs in approximately 3-4 hours using basic hand tools
$199.00
- Fits 1979-04 Mustang w/o independent rear suspension
- Eliminate wheel hop, improve traction, decrease body-to-rear end flex
- Fully adjustable for pinion angle, which greatly improves traction
- Installs in approximately 1-2 hours using basic hand tools
