Im always one of those guys who looks at things with the "if the factory didnt think it needed it; then why bother?" With multilayer steel headgaskets and the contact patch between the cylinder head and head bolts, its likely there is enough good contact area there to provide a good electrical connection between the top end and the engine block. Its easiest enough to check... just use a ohm-meter to check the resistance between a cylinder head and the chassis side of the ground strap and again between the engine block and the chassis end.
"If the factory didn't need it" - you and I are on different ends of the spectrum then as I can think of sooo many things the factory should have included but did not. Not sure what kind of gaskets I used but I don't remember them being metal. I am going to check the impedance once I have it ready. The local audio shops want a buck each for 8 awg ring terminals, no thanks I can wait(ordered in their parking lot).
I am going with 8 awg just because that is about the thinnest wire I run with I run power wires. I am willing to bet a 12 awg would be more then plenty but I am going to be sure
I had another thing get pointed out to me on the short 4 hrs I manage to make it at the holley classes I am curious what the debate would lead to. The HP EFI system from holley naturally recomends connecting its 12 awg power wires directly to the battery for power. I have two batteries in the trunk, one that is stock size and one larger battery and 0 awg power/ground going up to the front. Along the way it intercepts an isolator and as well as the dist blocks for the big ass amps I plan on adding before I connect to a fused dist block up under the hood. I connected an 8 awg power for the holley panel to the fuse box under the hood thinking closer to the alt = better and because if I put it in the rear the amps will be between the alt/battery and they can draw some current. I am not going to argue with the expert from holley as it has troubleshot 10x more systems then I have installed and because of this I am rerunning my power wires. Am I nuts to think what I thought?
