Thanks everyone. There are obviously quite a few things going on here, so I’ll try to answer everything as clearly as I can.
First, just to avoid confusion:
the complete stock upper and lower intake are currently back on the engine. The BigDog GT40 is off the car and sitting on the shelf.
So anything I answer about the GT40 now is based on the previous installation, pictures and the parts I still have. I’ll do my best to check or measure anything you guys think could be useful.
@ttocs – timing is still on my list. I tried checking base timing, but I’ve had trouble getting a reliable reading from the marks on the harmonic balancer, so I don’t want to claim that the timing is definitely correct yet.
I also tried moving the distributor slightly as a test and didn’t notice any meaningful change in the way the engine runs.
@96blak54 – the gasket set used when the BigDog GT40 was installed was
Fel-Pro MS95952. From what I can find, the actual lower intake-to-head gaskets included in that set are Fel-Pro
95952, with approximately 1.28” x 1.98” port openings.
I don’t know whether BigDog removed any material from the actual mating surfaces or only ported the runners/ports.
Is there anything I can measure on the GT40 lower while it is off the car that would help determine whether the mating surfaces have been machined and what gasket thickness it would need?
I’ll also ask the mechanic if the old GT40 intake gaskets still exist. If they do, I’ll get them back and take pictures of the impressions.
The stud kit sounds like a very good idea if/when the GT40 goes back on.
@Mustang5L5 – the internal EGR passage on the BigDog GT40 was already blocked. It looks like some kind of sealant/RTV was used to block it. I can take some detailed pictures of exactly how it was done if that helps.
And just to add another piece to the puzzle, I repeated the compression test on September 12.
Cold engine, all 8 plugs removed and fully charged battery:
1 – 135 psi
2 – 125 psi
3 – 125 psi
4 – 130 psi
5 – 140 psi
6 – 140 psi (the mechanic measured 60 psi on this cylinder after removing the GT40 and reinstalling the stock intake)
7 – 125 psi
8 – 110 psi (the mechanic measured 40 psi on this cylinder after removing the GT40 and reinstalling the stock intake)
I also did a wet test on #8 and it stayed exactly the same:
110 psi dry → 110 psi wet.
My compression numbers seem to vary somewhat between tests, although overall they actually seem to be improving. #8 is still consistently the lowest cylinder, though.
I also have some recordings of the engine noise I’ve been trying to describe(They were recorded safely). There is a strange “fluffing”/hissing sound, particularly at
WOT from low RPM, and that’s also where the car feels noticeably weaker than it used to.
Almost WOT with flutter:
www.dropbox.com
Just the whistling sound close to the dash (might be hard to hear but it’s there at the end of the clip)
www.dropbox.com
WOT clear flutter & whistling sound:
www.dropbox.com
Idle (sounds normal to my ears):
www.dropbox.com
I’ve replaced both small EGR vacuum hoses and the hoses at the rear vacuum T-fitting since my first smoke test. My next job is another smoke test to see what leaks remain.
At the moment my plan is basically to get the engine running properly with the
stock intake first, and only then think about putting the BigDog GT40 back on.
Any obvious checks or diagnostic tests I can do myself are very welcome.
And apologies for turning this into a slightly messy
“help, my Mustang has 1,000 symptoms at once” thread. I’m trying to work through them one at a time now.
