guestimate hp/ 1/4time
94IVGT
Northcentral, IL
new motor here by wednesday.
Dart block.
eagle forged rotating assm. 331ci 8.3:1 compression
twisted wedge heads
1.6rr
B451hr cam. shift point 6950rpm
victor 5.0intake
bbk longtubes-x pipe- flowmasters
255lph intank- trex inlike- afpr- 42lb injectors- 95mm PMAS MAF- 75mm tb
vortech 14-15 lbs of boost
billet steel flywheel
sfi dampner
smog delete
viper spec 6sp
detroit locker- 373's- moser axles
mt drag et streets.
tubular uca's
adjustable mm lca's
stage 3 clutch
PMS tuned
mallory ignition
battery relocation
prokit springs
might be forgetting some stuff ask if any other info is needed
justinschmidt1
sounds like a beast to me...
10.675 at 134 mph
lol...I dont really know..just guessing
Sounds like a 6-7 hundred hp car at the wheels
Paul
Neat. Post pics when you get it.
No idea on hp/tq numbers since guessing doesn't add much value anyway.
Track numbers depend on how good of a driver you are and how much seat time you have. :)
Paul.
94IVGT
Northcentral, IL
for sure ill definately get you guys the pics and true dyno numbers as soon as its finished up. hopefully by june
Paul
So I take it you ordered the motor complete/assembled? Where from? How much?
IceMan
600 is probably the most you will make with the 42's on there... you need more fuel if you want to see more than 600 whp. On a stock ECU you can run up to 60 lb injectors... After that you are going to need a injector driver...
94IVGT
Northcentral, IL
yes the shortblock is coming assembled. ill do the rest when it gets here. its from Brian at ADPerformance. He's pretty cool to bullshit with, which i like. if i cant call or talk to someone and them not give me a runaround and beat around the bush ill deal with them anyday. as for price 5993.that includes the link bar lifters, cam install and degree, 1/2 head studs, cometic head gaskets, shipping, sfi balancer, rollmaster billet timing set, cam plate.
94IVGT
Northcentral, IL
i figured id be close or past the limits of the injectors so ive got a little cash put away for them if need be. but if i do need them 60s will suit me
